Modify Structural Member Start/End Point
ChrisPicklesimer
327 Vistas
0 Respuestas
Mensaje 1 de 1
ChrisPicklesimer
I am trying to modify the start and/or end points of a structural member.  I assumed I would be able to modify the StartPoint and EndPoint property of the structural member in a similar way in which I modify Line StartPoint and EndPoint properties. See code below.    The sub where I attempt to manipulate the structural member blows up at the indicated line below.
Anyone know how to modify Start/End Point of a stuctural member or can point me in the right direction?
Thanks.
Chris
    Public Sub ChangeStartPointLine()
        Dim pt As Point3d
        Dim myID As ObjectId = GetEntityID(pt)
        Dim myLine As Line
        Dim ed As Editor = AcApp.Application.DocumentManager.MdiActiveDocument.Editor
        Dim db As Autodesk.AutoCAD.DatabaseServices.Database = ed.Document.Database
        Using tr As Transaction = db.TransactionManager.StartTransaction()
            Dim mypt As New Point3d(0, 0, 0)
            myLine = tr.GetObject(myID, OpenMode.ForWrite)
            myLine.StartPoint = mypt '<<<<<<<<<<<<<<<<<<<<<<<<<<<Works
            tr.Commit()
        End Using
    End Sub
Public Sub ChangeStartPointMember()
        Dim pt As Point3d
        Dim myMember As Autodesk.Aec.Structural.DatabaseServices.Member
            myMember = tr.GetObject(myID, OpenMode.ForWrite)
            myMember.StartPoint = mypt '<<<<<<<<<<<<<<<<<<<<<<<<<<<Does not work
            tr.Commit()
        End Using
    End Sub
    Public Function GetEntityID(ByRef pt As Point3d) As ObjectId
        Dim myObjID As ObjectId
        myObjID = Nothing
        'get working database
        Dim dwg As Database = ed.Document.Database
        Dim prGetEntity As PromptEntityOptions = New PromptEntityOptions(ControlChars.NewLine & "Select entity:")
        prGetEntity.SetRejectMessage(ControlChars.NewLine & "You must select an entity:.")
        'prGetEntity.AddAllowedClass(GetType(Wall), False)
        Dim resGetEntity As PromptEntityResult = ed.GetEntity(prGetEntity)
        If resGetEntity.Status = PromptStatus.OK Then
            myObjID = resGetEntity.ObjectId
            pt = resGetEntity.PickedPoint
        Return myObjID
    End Function
0 Me gusta
328 Vistas
0 Respuestas
Respuestas (0)
