C# code to insert a block
I’m trying to write a C# program which will insert a block in a drawing without opening the Autocad application. I’m ok to run the Autocad application as a background process. Can anyone help me out??
Virupaksha_aithal
Autodesk Support
Autodesk Support
See if AccoreConsole.exe helps to address your issue. refer  https://adndevblog.typepad.com/autocad/2012/04/getting-started-with-accoreconsole.html for getting started with AccoreConsole.
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
