Learning AutoCAD c# .net
Hi
I am new to AutoCAD C# programming and I couldn't find a comprehensive reference to learn it.
Could you please help me to find some good resources for learning AutoCAD .net programming?
_gile
Assuming that you already have a good knowledge of AutoCAD and the basics of .NET programming with C # (which are essential before you start programming AutoCAD with .NET), you will find the documentation for AutoCAD .NET on this page with a first exercise starting from here.
You can also try some "AutoCAD 201X .NET Training" tutorial on this page (I recommend you do not start with "My First AutoCAD Plug-In" which deals with advanced APIs).
Gilles Chanteau
GileCAD
GitHub
Thank you very much.
Is there any pdf about this topic?
it's easier for me to read a pdf than online documents.
kerry_w_brown
Not that I've seen.
Have you attempted printing the pages to PDF yourself ??
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
kerry_w_brown
Try the attached :
Thank you for your suggestion.
I will try it!
