c# code to add new attribute value to a block
Message 1 of 23
I wanted to add new attribute value to block by opening a autocad drawing & selecting block for which the new attribute value should be added
Replies (22)
Message 21 of 23
Thank you so much for ur quick response it seriously helped me a lot
Message 22 of 23
dk-tradserv
Thank you for the Code,
Unfortunately the inserted attribute does not appear in the block editor.
Block Attribute
Block Editor
What could be the problem?
Message 23 of 23
_gile
Block Attribute
Block Editor
As said in replies #6 and #8, the attribute is added to some block reference, not to the block definition (which is what you see in the block editor).
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
