c# code to add new attribute value to a block
Message 1 of 23
I wanted to add new attribute value to block by opening a autocad drawing & selecting block for which the new attribute value should be added
Replies (22)
Message 2 of 23
_gile
In view of all your recent posts, could you elaborate about the context in which you wish to do this (in-process vs out-of-process)?
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 3 of 23
I want to open a autocad drawing and select the block & in the program I want a textbox & a button the value given the user in the textbox should be added to the selected block by clicking on the button
Message 4 of 23
_gile
Sorry, but it's still not clear to me.
Do you want to create a custom AutoCAD command or, again, do that from a standalone executable, which is a completely different (and not so easy) process?
Is the block selected by the user a particular block? If so, is it dynamic? What's its name? Does it contain one or more attributes?
Is it to add an attribute or modify the value of an existing attribute? In any case, what is the label of the attribute?
And, if possible, show what you have done so far.
Gilles Chanteau
GileCAD
GitHub
Message 5 of 23
imagine I have a autocad drawing it contains "n" number of block & each block has many attributes but now the user wants to add a new attribute value for a particular block which he wants to be added so he has to select the block first & then add the new attribute to that block
Message 6 of 23
_gile
Do you want to only add an attribute reference to the selected block reference or add an attribute definition to the block definition and then synchronize all the references?
Gilles Chanteau
GileCAD
GitHub
Message 7 of 23
I would like to add an attribute reference to the selected block reference.
Message 8 of 23
_gile
You certainly know that this kind of attribute reference will be erased if the ATTSYNC command is run for this block.
Here's an example of AutoCAD plugin (i.e., a class library DLL which have to be netloaded in AutoCAD) containg custom command which shows a little dialog box to let the user enter the attribute value, then it prompts the user to select a block reference and specify the attribute insertion point.
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
namespace AmazingRequestSample
    public class Commands
        [CommandMethod("ADDATTREF")]
        public static void AddAttributeReference()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            // display a dialog box to get the attribute value
            string attValue;
            using (var dialog = new AttributeValueDialog())
                if (Application.ShowModalDialog(dialog) != System.Windows.Forms.DialogResult.OK)
                    return;
                attValue = dialog.AttributeValue;
            // prompts the user to select a block reference
            var peo = new PromptEntityOptions("\nSelect block reference: ");
            peo.SetRejectMessage("\nSelected object is not a block reference.");
            peo.AddAllowedClass(typeof(BlockReference), true);
            var per = ed.GetEntity(peo);
            if (per.Status != PromptStatus.OK)
                return;
            // prompts the user to specify the attribute insertion point
            var ppr = ed.GetPoint("\nSpecify the attribute insertion point: ");
            if (ppr.Status != PromptStatus.OK)
                return;
            var insPoint = ppr.Value.TransformBy(ed.CurrentUserCoordinateSystem);
            // create the attribute reference and add it to the attribute collection of the selected block
            using (var tr = db.TransactionManager.StartTransaction())
                var br = (BlockReference)tr.GetObject(per.ObjectId, OpenMode.ForWrite);
                var attRef = new AttributeReference(insPoint, attValue, "TAG", db.Textstyle)
                { LockPositionInBlock = false };
                br.AttributeCollection.AppendAttribute(attRef);
                tr.AddNewlyCreatedDBObject(attRef, true);
                tr.Commit();
The dialog box
using System.Windows.Forms;
    public partial class AttributeValueDialog : Form
        public AttributeValueDialog()
            InitializeComponent();
            AcceptButton = buttonOk;
            CancelButton = buttonCancel;
            buttonOk.DialogResult = DialogResult.OK;
            buttonCancel.DialogResult = DialogResult.Cancel;
        public string AttributeValue => textBoxAttValue.Text;
Gilles Chanteau
GileCAD
GitHub
Message 9 of 23
Thank you so much for ur quick response
Message 10 of 23
I'm getting error in the below line
var attRef = new AttributeReference(insPoint, attValue, "TAG", db.Textstyle) { LockPositionInBlock = false };
Use of unassigned local variable "attValue" but i have assigned the variable
Message 11 of 23
_gile
I do not have such error.
Is it an error at edition time (which prevent the compilation in Visual Studio) or an exception thrown at running time?
Gilles Chanteau
GileCAD
GitHub
Message 12 of 23
It is an error at edition time
Message 13 of 23
_gile
Your project should contains 2 classes:
  • Commands.cs where the command is defined
  • AttributeValueDialog.cs the dialog box decription
Gilles Chanteau
GileCAD
GitHub
Message 14 of 23
Message 15 of 23
_gile
You didn't correctly the code i posted.
Replace:
            string attValue;
with:
            string attValue;
                    return;
Gilles Chanteau
GileCAD
GitHub
Message 16 of 23
Ya I m sorry. Thank you for correcting me
Message 17 of 23
Thank you sooo much it worked successfully
Now I want an enhancement in that code. I want to add the attribute value by selecting multiple blocks how can we do that??
Message 18 of 23
_gile
You can use a selection set got with Editor.GetSelection() and a selection filter instead of Editor.GetEntity() and then, for each selected entity, prompt the user to specify the insertion point and add the attribute reference.
Gilles Chanteau
GileCAD
GitHub
Message 19 of 23
Can u send me the code
Message 20 of 23
_gile
Claiming a code is not a good way to learn.
            string attValue;
                    return;
            // prompts the user to select block references
            var filter = new SelectionFilter(new[] { new TypedValue(0, "INSERT") });
            var psr = ed.GetSelection(filter);
            if (psr.Status != PromptStatus.OK)
                return;
            dynamic acadApp = Application.AcadApplication;
                foreach (SelectedObject so in psr.Value)
                    var br = (BlockReference)tr.GetObject(so.ObjectId, OpenMode.ForWrite);
                    br.Highlight();
                    br.Unhighlight();
                        continue;
                    db.TransactionManager.QueueForGraphicsFlush();
                tr.Commit();
Gilles Chanteau
GileCAD
GitHub
