block explode vb.net
this program insert a block in a dwg, works wonderfull. my problem is, after block insert i will explode this block. what can i do ? thanks for ideas
Option Explicit On
Imports System
Imports System.Type
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports acadApp = Autodesk.AutoCAD.ApplicationServices.Application
Imports Autodesk.AutoCAD.Geometry
Imports DBTransMan = Autodesk.AutoCAD.DatabaseServices.TransactionManager
Public Class AdskClass1
_
Public Function Asdkcmd1()
Dim insertionPoint(2) As Double
Dim Comp As String
Comp = "d:\temp\test.dwg"
insertionPoint(0) = 10 : insertionPoint(1) = 20 : insertionPoint(2) = 0
Dim doc As Document = acadApp.DocumentManager.MdiActiveDocument
Dim ed As Editor = doc.Editor
Dim tr As Transaction = doc.TransactionManager.StartTransaction
Try
Dim dwgName As String = HostApplicationServices.Current.FindFile(Comp, acadApp.DocumentManager.MdiActiveDocument.Database, FindFileHint.Default)
Dim db As Database = New Database(False, False)
db.ReadDwgFile(dwgName, IO.FileShare.Read, True, "")
Dim BlkId As ObjectId
BlkId = doc.Database.Insert(dwgName, db, False)
Dim bt As BlockTable = tr.GetObject(doc.Database.BlockTableId, OpenMode.ForRead, True)
Dim btr As BlockTableRecord = tr.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite, True)
Dim bref As BlockReference = New BlockReference(New Autodesk.AutoCAD.Geometry.Point3d(insertionPoint), BlkId)
btr.AppendEntity(bref)
tr.AddNewlyCreatedDBObject(bref, True)
tr.Commit()
Catch ex As Exception
ed.WriteMessage(ex.ToString)
End Try
End Function
End Class
the program is now working 🙂
Option Explicit On
Imports System
Imports System.Type
_
Dim Comp As String
Try
bref.ExplodeToOwnerSpace()
bref.Erase()
tr.Commit()
End Try
End Function
End Class
