block explode vb.net
04:13 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
this program insert a block in a dwg, works wonderfull. my problem is, after block insert i will explode this block. what can i do ? thanks for ideas
Option Explicit On
Imports System
Imports System.Type
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports acadApp = Autodesk.AutoCAD.ApplicationServices.Application
Imports Autodesk.AutoCAD.Geometry
Imports DBTransMan = Autodesk.AutoCAD.DatabaseServices.TransactionManager
Public Class AdskClass1
_
Public Function Asdkcmd1()
Dim insertionPoint(2) As Double
Dim Comp As String
Comp = "d:\temp\test.dwg"
insertionPoint(0) = 10 : insertionPoint(1) = 20 : insertionPoint(2) = 0
Dim doc As Document = acadApp.DocumentManager.MdiActiveDocument
Dim ed As Editor = doc.Editor
Dim tr As Transaction = doc.TransactionManager.StartTransaction
Try
Dim dwgName As String = HostApplicationServices.Current.FindFile(Comp, acadApp.DocumentManager.MdiActiveDocument.Database, FindFileHint.Default)
Dim db As Database = New Database(False, False)
db.ReadDwgFile(dwgName, IO.FileShare.Read, True, "")
Dim BlkId As ObjectId
BlkId = doc.Database.Insert(dwgName, db, False)
Dim bt As BlockTable = tr.GetObject(doc.Database.BlockTableId, OpenMode.ForRead, True)
Dim btr As BlockTableRecord = tr.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite, True)
Dim bref As BlockReference = New BlockReference(New Autodesk.AutoCAD.Geometry.Point3d(insertionPoint), BlkId)
btr.AppendEntity(bref)
tr.AddNewlyCreatedDBObject(bref, True)
tr.Commit()
Catch ex As Exception
ed.WriteMessage(ex.ToString)
End Try
End Function
End Class
Option Explicit On
Imports System
Imports System.Type
Dim Comp As String
Try
tr.Commit()
End Try
End Function
End Class
