AutoLoad the dll on AutoCAD startup
prem_kumar8SXZJ
Message 1 of 16
prem_kumar8SXZJ
Hi everyone,
I have created a small plugin in AutoCAD using c# and right now I am using netload to load my dll into AutoCAD.
But I want that when I start my AutoCAD the DLL will automatically load. I tried to create a bundle file including the PackageContents.xml file and place my dll into the bundle folder. But the DLL is not loading automatically.
If anyone has any idea then please help me.
Replies (15)
Message 2 of 16
Ed__Jobe
Where do you have the bundle folder stored? In one of the areas that AutoCAD looks for them? Your personal area is located at %AppData%\Autodesk\ApplicationPlugins
Ed
How to post your code.
Message 3 of 16
_gile
In this reply, an example of minimalist PackageContents.xml file for autoloading a .NET DLL.
Gilles Chanteau
GileCAD
GitHub
Message 4 of 16
prem_kumar8SXZJ
Hi, Where I can find this product code and upgrade code? So that I can include them in the PackageContents.xml file?
ProductCode="{83F90232-3CEB-40F0-88BE-2638C843CEA5}"
UpgradeCode="{B31D4C65-464B-4460-9E9F-B36D7B1C453A}"
Message 5 of 16
_gile
You do not "find" them, you create them (there's a "Create GUID" in the Visual Studio Tools menu and many other on the web).
ProductCode shoud be changed a each new version. UpgradeCode should never be changed.
Gilles Chanteau
GileCAD
GitHub
Message 6 of 16
prem_kumar8SXZJ
Hi I have created a product code using GUID and Created a folder with a .bundle file and also created all the sub folders and PackageContents.xml file and Paste that bundle folder in C:\Program Files (x86)\Autodesk\ApplicationPlugins\Trapeze.bundle this directory, But still, my dll is not loading why?
Message 7 of 16
_gile
The 'Trapeze.bundle' was just an example you have to adapt to suit your needs.
Name the .bundle as you need (typically as you project), create new GUIDs for both the ProductCode and the UpgradeCode, change the application Name, Set the SeriesMin and SeriesMax value to the AutoCAD releases you want your app to run on, change the AppName and, for sure, the ModuleName.
You should read this topic and the related references.
Gilles Chanteau
GileCAD
GitHub
Message 8 of 16
prem_kumar8SXZJ
Hi, I have made all the changes and when I open AutoCAD it also shows the message "Stretch Utility has been successfully loaded" where Stretch Utility is my Application name. But then again when I give the command to run some functionality that I written in the Dll, It is saying Unknown command. If I use Netload and then use the command everything is working fine. I don't understand what is going on with the bundle file.
<?xml version="1.0" encoding="utf-8"?>
<ApplicationPackage
  SchemaVersion="1.0"
  AppVersion="1.0.0"
  ProductCode="{04A0B285-1593-4604-B4B1-714A231770CD}"
  Name="Stretch Utility"
  AutodeskProduct="AutoCAD"
  ProductType="Application">
  <Components>
    <RuntimeRequirements OS="Win32|Win64" Platform="AutoCAD|AutoCAD*" SeriesMin="R24.3" SeriesMax="R24.3" />
    <ComponentEntry
      AppName="Stretch Utility"
      Version="1.0.0"
      ModuleName="./Contents/AutoCAD_3DProject.dll"
      LoadOnAutoCADStartup="True">
    </ComponentEntry>
  </Components>
</ApplicationPackage>
Message 9 of 16
_gile
Do not care about your application Status is "Unknown App" in the application manager dialog. This is due to the fact you application is not one from the Autodesk Application Store.
Does your application contains a class which implements IExtensionApplication? If so, your issue may be due to what does the Initialize method because this method is not called in the same context when the application is autoloaded or when it is netloaded.
Gilles Chanteau
GileCAD
GitHub
Message 10 of 16
prem_kumar8SXZJ
Yes, my class does implement IExtensionApplication because I am creating a ribbon tab and some buttons. I just removed the code for the ribbon tab and now it is loading perfectly. Thanks.
One more question is If I don't use the IExtensionApplication then how I am going to create a ribbon tab and some buttons? Is it through cuix file or there is any other way?
Message 11 of 16
_gile
You can use IExtensionApplication, but you have to take care of the context the Initialize() method is run.
Typically, you just subscribe to the Application.Idle event in the Initialize method and do your stuff in the event handler to ensure the code is not run before AutoCAD completed its own initialization.
Here's a example:
internal class ExtensionApplication : IExtensionApplication
    public void Initialize()
        Application.Idle += OnIdle;
    private void OnIdle(object? sender, EventArgs e)
        var doc = Application.DocumentManager.MdiActiveDocument;
        if (doc != null)
            Application.Idle -= OnIdle;
            try
                // Do the initialization stuff here.
            catch (System.Exception ex)
                doc.Editor.WriteMessage($"\nInitilization error: {ex.Message}");
    public void Terminate()
You can also use this ExtensionApplicationAsync abstract class from @ActivistInvestor.
Gilles Chanteau
GileCAD
GitHub
Message 12 of 16
prem_kumar8SXZJ
Okay, Thanks for this 😀
Message 13 of 16
OttoDV
My apologies, I know this is an old topic, but I'm still struggling with this same issue too. I have tried several combinations and followed plenty of manuals in setting up the PackageContents.xml file, even the one above, to no avail. Is there anyone that can help loading my DLL in Civil 3D specific. I've even tried the just AUTOCAD one too. I've attched my file for scrutiny.
Message 14 of 16
ActivistInvestor
My XML viewer app (on Android) can't open the file, and displays the following error:
This page contains the following errors:
error on line 32 at column 20: Opening and ending tag mismatch: Command line 28 and Commands
Message 15 of 16
CodeDing
@OttoDV ,
I fixed your tags (added 3 "/" marks), I did not check anything else.
Attached is XML
Best,
~DD
Message 16 of 16
kerry_w_brown
Perhaps this will solve the issue  . . . at least for file structure ?
Summary of Changes:
1. Fixed invalid nesting of <Command> tags.
2. Added missing closing tags for <RuntimeRequirements> and <Components>.
3. Removed unnecessary spaces in attributes.
4. Added comments for clarity.
5. Ensured the XML structure is valid and consistent.
<ApplicationPackage
   SchemaVersion="1.0"
   AppVersion="1.0.1"
   ProductCode="{79A0236D-3C13-47FB-8BC0-C84EC8A3656E}"
   UpgradeCode="{AD0E3688-98E2-440E-8F51-D4EA8CC1AC24}"
   Name="RSA Cogo Importer"
   Description="A custom plugin for Civil 3D to import RSA Cogo points"
   <!-- Runtime Requirements -->
   <Components>
         OS="Win64"
         SeriesMin="R25.0"
         SeriesMax="R26.3">
      </RuntimeRequirements>
      <!-- Component Entry -->
      <ComponentEntry
         AppName="RSA_Cogo_importer"
         Version="1.0.1"
         ModuleName=".\Contents\RSA_Cogo_importer.dll"
         <!-- Commands -->
         <Commands GroupName="MyPluginCommands">
            <Command
               Local="RSACSVIMPORT"
               Global="RSACSVIMPORT"
               StartupCommand="True" />
            <Command
               Local="RSAUNLOADDIA"
               Global="RSAUNLOADDIA"
         </Commands>
      </ComponentEntry>
   </Components>
Stay well,
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
