AutoCad plugin development for both windows and Mac
vishu_guntupalli
Observer Observer
vishu_guntupalli
Observer
Observer
Hello, I currently have an AutoCad plugin that was written in C# .NET and it has the dependency on AutoCad.NET library which uses the .NET framework, so I am unable to do any development of this plugin or run it on Mac.
1. Is there a way to port this plugin over to Mac using mono or similar ?
2. Is there a way to develop AutoCad plugins that run on both Windows and Mac using the same codebase?
Thanks.
maxim_k
Hi @vishu_guntupalli ,
I think it is better ask your question here:
https://forums.autodesk.com/t5/net/bd-p/152
You can also look at this thread:
https://forums.autodesk.com/t5/net/can-i-use-c-for-making-auto-cad-plugin-for-both-windows-and-mac/t...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
ActivistInvestor
AutoCAD For Mac is severely limited insofar as API support goes. Mono wouldn't help because the Autodesk .NET API doesn't target it, and doesn't work with it AFAIK.
That means you are limited to the legacy AutoLISP/DCL (e.g., no vl-* functions, no ActiveX, etc.), or native ObjectARX/C++.
daniel_cadext
There’s no C++/CLI compiler for Mac (Required for .NET). Microsoft stated they have no plans to port it.
So that means ARX, and if you need a GUI, that would mean QT or wxWigets
I’ve done a considerable amount of work in C++ / wxWigets, though it was not my responsibility to do the alt platform builds.
In general, you use the same code base, except initialization.  Once you get setup, and with modern C++20, it’s not bad at all.
Though you will need to become a master at unit testing.
I’ve been thinking about this a bit as I also want to port my Python wrappers to Alt platforms (someday)
Hooking wx into AutoCAD for windows is easy.
https://github.com/CEXT-Dan/PyRx/blob/9dc90d8928cf2892350d40f1353718a97998e8da/PyRx/PyRxApp.cpp#L23-...
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
