Can I use C# for making auto-cad plugin for both Windows and Mac.
Message 1 of 9
Currently I am working on a project and I am using C# in objectARX. At the end of my project i found that i cannot use the same C# code on Mac. Is there any solution available so that i can make the autocad plugin using same C# code that i have used for developing it for windows.
I have searched that i can use same code for both platforms if i work on c++.  So, is using c++ the only option or i can make it using c# too.
Please help.
Replies (8)
Message 2 of 9
ActivistInvestor
Please help.
No C# or .NET on MAC.
While there are .NET runtimes and development tools for the MAC, they're not supported by Autodesk, and without that support you can't use .NET or C# to build apps for AutoCAD MAC.
Message 3 of 9
Does it mean that i can only use C++? Only it will help me in developing plugin that works on Mac and Windows while having same code?
Message 4 of 9
ActivistInvestor
It's either C++ or a subset of LISP (no vlax/vla-* or windows-specific functions).
It's kind of like AutoCAD Release 14
Message 5 of 9
KIMHENGHOR98
Autocad now has new vision of Autocad 2023 which supports Mac M Series but I don’t know if it works with .Net
Message 6 of 9
_gile
AutoCAD .NET requires to use the .NET Framework (not .NET Core) and the .NET Framework only supports the Windows operating system.
Gilles Chanteau
GileCAD
GitHub
Message 7 of 9
KIMHENGHOR98
Installing Window OS on Mac may work out.
Message 8 of 9
KIMHENGHOR98
If I am running Window by Bootcamp on Mac m series ,Does C# work with Autocad?
Message 9 of 9
Ed__Jobe
@KIMHENGHOR98 Asking the same question in three different threads is not polite. I merged your other two threads into one. See the answer there.
Ed
How to post your code.
