AutoCAD 2011 compatibil with windows 10
We have installed Windows 10 64 bit, on this OS we have installed Autocad 2011, but text & dimensions are missing on the drawing
Before installed windows 10 we have windows 7 on W7 Autocad 2011 is working fine.
How to fix this issue with Windows10
_gile
Thanks for riplying on this,
do we have any patch availabe to run this.
Do we have any path file to run this software version
mhillis
As previously stated, 2011 is NOT supported by Autodesk on Windows 10.  This means that they have not and will not publish a patch that promises compatibility of 2011 on Windows 10.
This does not mean it will not work, but it is almost luck of the draw at this point.  The only thing you can really do is install .NET 3.5, install AutoCAD 2011 and hope for the best.
Thanks for replaying me, i have done some changes in . Net frame work but still i have same problem
Auto cad 2011 & drawing can Open properly only thing is that i am not able to entered characters & command line.
This issue i face after installation of Windows 10.
Install service pack 2 and Autocad 2011 will work with windows 10.
