acdbWcs2Ucs in vb.net ?
In C i was using the functions acdbWcs2Ucs to convert from one coordinate
system to another.
Because I can't find the function in VB i've made following function
CallingConvention:=CallingConvention.Cdecl)> _
Public Function acdbUcs2Wcs(ByVal fromPoint As Double(), ByVal toPoint
As Double(), ByVal vector As Boolean) As Integer
End Function
but when i'am using the function Acad crashes.
Any idea ?
Or another solution to convert from WCS2UCS, UCS2WCS, DCS2WCS,.... in vb ?
tnx,
Peter
EntryPoint:="?acdbUcs2Wcs@@YA_NQAN0_N@Z",
Public Shared Function acdbUcs2Wcs( ByRef inPt As Point3d, ByRef outPt As Point3d, ByVal vec As Boolean) As Boolean
End Function
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
"Peter Warnez" wrote in message news:5541564@discussion.autodesk.com...
system to another.
End Function
Any idea ?
tnx,
Peter
Hi. Don't use the declaration I posted in the last
message.
Autodesk's news server has mangled it.
To call the degree of stupidity and
size=1>ignorance reflected
by the design of Autodesk's online
size=1>discussion groups
astonishing, is an understatement.
I'll try it one more time:
<DllImport("acdb17.dll", EntryPoint:="?acdbUcs2Wcs@@YA_NQAN0_N@Z", CallingConvention:=CallingConvention.Cdecl)> _
Public Shared Function acdbUcs2Wcs(<Out> ByRef inPt As Point3d, <Out> ByRef outPt As Point3d, ByVal vec As Boolean) As Boolean
End Function
Supporting
size=1>http://www.acadxtabs.com
system to another.
Because I
function
<DllImport("acad.exe", EntryPoint:="acdbUcs2Wcs",
As
    End
Function
Any idea
vb ?
tnx,
Peter
And sorry about all the embedded hyperlinks in the code
(actually it would be great if it lead you to the related
MSDN or other docs, rather than to Lutz Roeder's website).
"Tony Tanzillo" wrote in message news:5541646@discussion.autodesk.com...
Hi. Don't use the declaration I posted in the last message.
To call the degree of stupidity and ignorance reflected
by the design of Autodesk's online discussion groups
_
Public Shared Function acdbUcs2Wcs( ByRef inPt As Point3d, ByRef outPt As Point3d, ByVal vec As Boolean) As BooleanEnd Function
-- http://www.caddzone.com
system to another.
End Function
Any idea ?
tnx,
Peter
Tnx a lot
Where can I find all that kind of stuff ?
If don't understand the way the function works....
greetings,
Peter
"Tony Tanzillo" schreef in bericht
news:5541652@discussion.autodesk.com...
system to another.
End Function
Any idea ?
tnx,
Peter
Read this topic: http://through-the-interface.typepad.com/through_the_interface/2006/07/calling_objecta.html
You can use Depends.exe to look up exported functions
and their signatures.
"Peter Warnez" wrote in message news:5541748@discussion.autodesk.com...
Tnx a lot
greetings,
Peter
system to another.
End Function
Any idea ?
tnx,
Peter
