2008: LispFunctionAttribute Broken
Message 1 of 8
Can someone else confirm that code that
uses [LispFunction()] is completely broken
in AutoCAD 2008, and that you cannot call
LISP functions defined in managed code?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
Replies (7)
Message 2 of 8
This works for me Tony ..
Haven't tried ResBuff stuff though
(setq xxx (ConcatStrings "1" "2" "3"))
;;-> "123"
using your source ..
// Define Command
[LispFunction("ConcatStrings")]
static public string ConcatStrings(ResultBuffer args)
StringBuilder sb = new StringBuilder();
foreach (TypedValue rb in args)
if (rb.Value is string)
sb.Append((string)rb.Value);
return sb.ToString();
"Tony Tanzillo" wrote in message
news:[email protected]...
Message 3 of 8
Thanks Kerry.
Try this one:
[LispFunction("test")]
public static bool lisptest(ResultBuffer args)
return true;
"Kerry Brown" wrote in message news:[email protected]...
;;-> "123"
// Define Command
Message 4 of 8
Spat the dummy ... yuk !
System.ArgumentException: Error binding to target method.
at System.Delegate.CreateDelegate(Type type, Object firstArgument,
MethodInfo method, Boolean throwOnBindFailure)
MethodInfo method)
at AcMgCommandClass.InvokeWorker(AcMgCommandClass* , MethodInfo mi,
Object
commandObject, Boolean bLispFunction)
at AcMgCommandClass.InvokeWorkerWithExceptionFilter(AcMgCommandClass* ,
MethodInfo mi, Object commandObject, Boolean bLispFunction)
Thanks Kerry.
Try this one:
return true;
;;-> "123"
// Define Command
Message 5 of 8
This seems a bit of an overkill ...
public object lisptest(ResultBuffer args)
//TypedValue[] tva = args.AsArray();
//return true;
return new TypedValue(RTT, true);
/// kwb
Thanks Kerry.
Try this one:
return true;
;;-> "123"
// Define Command
Message 6 of 8
That could have been :
style="FONT-SIZE: 10pt; BACKGROUND: white; COLOR: black; FONT-FAMILY: Courier New">
style="COLOR: #2b91af">LispFunction
style="COLOR: #a31515">"test"
style="COLOR: blue">public
object
style="COLOR: #010001">lisptest
style="COLOR: #2b91af">ResultBuffer
style="COLOR: #010001">args
style="COLOR: green">// T
return new
TypedValue(
style="COLOR: #010001">RTT
style="COLOR: #a31515">"test1"
object
style="COLOR: #010001">lisptest1
style="COLOR: green">//nil
return new
TypedValue(
style="COLOR: #010001">RTNIL
.. but I'm flying blind
here
        public
args)
args.AsArray();
//return
true;
true);
kwb
"Tony Tanzillo" <
href="mailto:tony.tanzillo@THE_URL_BELOW.com">
size=2>tony.tanzillo@THE_URL_BELOW.com
wrote in message
face=Arial size=2>news:[email protected]
face=Arial size=2>...
Thanks Kerry.
Try this
one:
args)
    return true;
href="http://www.caddzone.com">
size=2>http://www.caddzone.com
size=2>AcadXTabs: MDI Document Tabs for AutoCAD 2008
through 2008
size=2>http://www.acadxtabs.com
"Kerry
Brown" <
size=2>kwb@home
> wrote in message
size=2>...
though
"123"
// Define Command
args)
StringBuilder();
args)
if (rb.Value is
string)
"Tony Tanzillo" <
wrote in message
uses
call
through 2008
Message 7 of 8
Whats a guy got to do to get decent formatting here ?
{ // T
return new TypedValue(RTT);
[LispFunction("test1")]
public object lisptest1(ResultBuffer args)
{ //nil
return new TypedValue(RTNIL);
.. but I'm flying blind here, and that sure doesn't answer the bool
question, I know.
Message 8 of 8
Thanks. The docs suggest that the return
type of the method can be any of the types
listed. It seems that the method must have
a return type of object, which of course can
box any of those types.
{ // T
{ //nil
//return true;
/// kwb
Thanks Kerry.
Try this one:
return true;
;;-> "123"
// Define Command
