You can select objects by properties under the Properties tab of the Selection Tree panel. You can also pick "Hide unselected" from the right-click context menu. Thats not limited to line numbers, and can be used for any unique available property.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
