Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Everything selected when opening NW2014
12 REPLIES 12
Message 1 of 13
dennis
934 Views, 12 Replies
When I open NW, it always defaults first thing with something selected.  If it is an NWC I am opening, it will select the entire NWC, or if I am opening an NWF, the last appended NWC will be selected.  Is there a way/setting/etc to stop this?
12 REPLIES 12
Message 2 of 13
MichaelBussiere2
in reply to: dennis
Thank you for your post.  In this case the issue looks linked to overall configuration of NW2014.  Has this always been the case?  Have you tried a repair to NW via the control panel to reset the software configuration and then test?  Please keep us posted and let us know how this worked out.  Thank you.
Michael Bussiere II
Support Specialist
Product Support
Autodesk, Inc.
Message 3 of 13
dennis
in reply to: MichaelBussiere2
I have completely clean uninstall and reinstall, SP and Hot fixed.  It still does it.  When I open a any NWF, NWD or NWC, it comes open and selected.
Message 4 of 13
DarrenP
in reply to: dennis
i see that here to
DarrenP
Message 5 of 13
DarrenP
in reply to: DarrenP
i'm wondering if this is a factory suite thing
DarrenP
Message 6 of 13
DarrenP
this doesn't happen with navisworks 2014 non suite with or without SP 1
currently testing with navisworks 2014 from factory design suite
DarrenP
Message 7 of 13
DarrenP
this does happen with navisworks 2014 from the factory design suite without service pack 1 and hotfix
DarrenP
Message 8 of 13
dennis
Kudos Darren.  WHile this problem isn't a show-stopper, it is aggrivating.
Message 9 of 13
dennis
Still happening and can't for the life of me figure out why.  I have tried settings every which a way.  I then exported my settings to xml and read into an install in our training room where Manage is not a part of the FDS.  It opened without the files selected.  So it ain't the settings.
Message 10 of 13
DarrenP
in reply to: dennis
its something with the factory ultities for navisworks
i just don't know what
DarrenP
Message 11 of 13
in reply to: dennis
 NW 2013 from Factory Suite also has this issue.
Message 12 of 13
DarrenP
did not know that
2014 is the first time i am installing navisworks from the factory suite
2013 i installed from the building suite
DarrenP
Message 13 of 13
DarrenP
navisworks 2015 from factory suite is doing the same thing
DarrenP
Rail Community
