I have seen several questions for this but no answers that I have seen that fit our needs.
We have NWCs from several other contractors and ourselves, everything lines up as desired there. The project is rotated slightly from True North with an origin point over 600 miles away, so running a dimension shows a rotation.
We want our dimensions to align straight but our models to not be moved in space; just the north rotation. The duct below is modeled in Revit at Project North and is straight from left to right, but in Navis (using True North) you see it is rotated.
![aruckerY7D6L_4-1715872840003.png aruckerY7D6L_4-1715872840003.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1363382iFA7C49EB45D2580A/image-size/medium?v=v2&px=400)
Yes, we can rotate everything in the Units and Transform window (given only one model at a time), this makes our dimensions work but if we send viewpoints made with this rotation to another trade, they are sent away from the model since they are not rotating their models.
Using the File Options > Orientation only changes which axis is north so this does not work either.
I also tried the "Set Current View as Front" option at the view cube and, while it did rotate the alignment of where Front is, the dimension still shows a rotation.
![aruckerY7D6L_1-1715872743825.png aruckerY7D6L_1-1715872743825.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1363377iE41CDFEAA8F42C62/image-size/medium?v=v2&px=400)
![aruckerY7D6L_2-1715872749764.png aruckerY7D6L_2-1715872749764.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1363379i818DFC381D3F5443/image-size/medium?v=v2&px=400)
Having all companies change how they export or run their Navis models isn't a viable option this far along in the process.
