Hi there,
I am using a rcs file and everything is ok inside plant 3d, xref file path is all good and the scan is on a locked layer so cant move. I export the plant3d file out to AutoCAD and then open Navis Manage and append the dwg, which has never been an issue before but this file the scan move so the tank is not on the pad.
I got my colleague to check on his machine and its the same, even moving everything to 0,0 cords produces the same result.
Any help would be appreciated.
![Navis incorrect.PNG Navis incorrect.PNG](https://forums.autodesk.com/t5/image/serverpage/image-id/1363300iB31799582D1FAD03/image-size/large?v=v2&px=999)
