Revit Navisworks 2019
brianwclayton1969
brianwclayton1969
Couldn't find a forum for Navisworks 2019. here is my issue, hoping to find assistance.......
I'm running Animator sequence on a design and when I create viewpoints for the outside views of the building and set up in the timeline. and Playback it all works fine. When I use the same steps to create a building with cut planes, to show the building being built from footing to roof creation, nothing happens. What's wrong? Has anyone experienced any bugs or issues in Navisworks 2019.
nmarcelis
You can find the Autodesk Navisworks forum here.
Revit Certified Professional Architecture, Structure and MEP.
Hi @brianwclayton1969 ,
If I understood your concern correctly, you are trying to create an animation that would section your model. If so, you may refer to the screencast attach.
If this resolves your issue, please click ACCEPT AS SOLUTION.
brianwclayton1969
Yes that was it, I really appreciate it. It worked like a charm
Again I appreciate the assistance.
