Product Update: Navisworks Coordination Issues Add-In 4.5.0
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Version 4.5.0 of the Navisworks Coordination Issues Add-In has been submitted to the Autodesk Apps store, and on manage.autodesk.com to be available shortly.
Prerequisites
Please uninstall prior versions of the product before installing the new version.
Product Improvements
- Issues: Added support for 'Watchers' and 'Start Date' in template creation.
- Issues: Updated the create issue functionality to provide the same experience no matter where or how you create an issue. This means that all locations to create should now have access to issue templates on creation.
- Issues: Added an option to cull issue pushpins. This option allows users to specify a distance in which issue pushpins render on the model. Moving through the model will render new pushpins and remove pushpins beyond the defined distance.
- Connected: Add support in Tip Viewing mode for new Content Definition settings.
- Connected: Coordination View and Model picker now available in the Home Screen in Navisworks 2025.
- Connected: UI update to the Coordination View and Model picker to be more consistent with Model Coordination.
- Connected: Coordination tab in the Navisworks Home Screen can now access project issues without the need to load the model and open the issues panel. Thus making it evening easier to see what issues of interest to you.
Stability and Defects
General fixes
- Issues: Resolved a defect where an Issue Status specified in the ACC Issue Template in Build is not applied in Navisworks
- Issues: Improved the user experience when a model is updated.
- Where one of the models (that is involved in a clash issue) is updated, a message appears in the issues panel and highlighting does not show in Navisworks.
- Where any other model is updated (not the 2 models involved in clash issue), clash highlighting appears as normal with both elements highlighted in Navisworks.
- Issues: Resolved an inconsistency where some issue screenshots would not be captured on issue creation.
Regards
Brett Parker
Navisworks Product Manager
