Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
nwd to nwc
7 REPLIES 7
Message 1 of 8
MohamedR.Nasreldeen
8689 Views, 7 Replies
nwd to nwc
is  there any method to extract nwc from nwd model ?
7 REPLIES 7
Message 2 of 8
No you cannot extract NWC from NWD. proprietary File Formats does not require cache file to open.
NWCs are Cache files  that is automatically generated when opening/appending native model files, such as files from Revit , AutoCAD or MicroStation. And when saved the file extension is either NWF or NWD.
Message 3 of 8
thanks for your response,sir
Message 4 of 8
Hi @MohamedR.Nasreldeen,
Like @a_meteni said you cannot do it, but you can always export the NWD as a DWF and the when you append that new file an NWC will be created automatically, you will loose all your properties but it is a workaround that works if you need a NWC from a NWD.
If this helped solve your problem please mark it as solution, so other users can get this solutions as well.
Valentin Noves
BIM Manager
www.valentinnoves.com
Message 5 of 8
Export an IFC file and open it in Navis. This will automatically create an NWC while maintaining property sets
Message 6 of 8
There have the Navisworks 2025 NWC File Export Utility.
https://www.autodesk.com/products/navisworks/3d-viewers
Message 7 of 8
KUANMAOCHEN
in reply to: novesvalentin
It doesn't work, shows internal error cause unload...
Message 8 of 8
KUANMAOCHEN
It's works when I use naviswork 2025 version!
export DXF and append on the same file will appear the NWC file on the same path.
Rail Community
