- Mute
- Permalink
- Report
I am using Autodesk Navisworks Simulate 2017.
I am very new to the program and trying to get a material take-off. The workflow I am using is per the getting started videos. I keep getting the error message that suggests I do not satisfy the following criteria:
"To carry out model takeoff, objects must be either a group, layer or model. If you try to takeoff a model object that is an instance, or if the object does not contain a GUID or properties, an error message is displayed."
In my case I selected "levels" or an object that shows as a "cell" in the selection tree, which appear in the selection tree as highlight blue selected items. I know the selection is either a "layer" or maybe a model but do not know how to confirm that it is being read properly since it appears to have originated as Bentley dgn type model format that uses levels and cells. Any suggestions on the easiest way I can do a quantity takeoff, if possible ?
