Navisworks Item Appearance Overrides
dn7QYDD
Message 1 of 9
dn7QYDD
When I apply color, or transparency overrides to model items, they do not save in my viewpoints. In the past, I have been able to change an objects color or transparency and it would reflect in my other viewpoints. Now, I change an objects color or transparency and navigate to other VPs and I not only lose those overrides in the other VPs but I also lose it in the original VP. I have tried all combinations of the Viewpoint Defaults in the options and nothing fixes the issue. I am working in Navisworks Manage 2021 but the problem exists when I use Navis Manage 2019 as well.
Replies (8)
Message 2 of 9
Ahmed_M_Heteba
i am using 2020, but it works fine for two or three transfers between vps and then reset automatically
could not figure why
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
Message 3 of 9
dn7QYDD
So your having the same problem then? Are you providing me a solution or just bring up the fact that you are experiencing the same issue?
Message 4 of 9
Ahmed_M_Heteba
i was trying to see a solution but i got the same problem 😞
Message 5 of 9
Ahmed_M_Heteba
check this from navisworks help it says that the change in the scene view not in the file or project
Message 6 of 9
dn7QYDD
Thank you for the suggestion, however I know how to change and items color or appearance so unfortunately this suggestion doesnt help
Message 7 of 9
Ahmed_M_Heteba
i didn't mean the steps..
the help says that the change is on the scene it is maybe the way it work not a problem
we can wait for other experience with this option to know the problem
Message 8 of 9
ShawnV83
Right click on one of your saved viewpoints, click edit.
Make sure that in the bottom left corner of dialogue that pops up, that the boxes under "Saved Attributes" are checked.
Message 9 of 9
lumbera_darwin
Hi @dn7QYDD ,
It seems that some of the existing viewpoints have the settings like this. The "Override Appearance" are checked in the Saved Attributes panel.
If you want to keep the colours on your viewpoint, right-click the saved viewpoints > Edit. Then make sure that the "Override Appearance" is checked. You may also check "Hide/Required" if you want to keep the objects hidden on your saved viewpoint.
Hope this helps.
Dar
