Navisworks AutoCAD Layers
david.forsyth8QZCL
david.forsyth8QZCL
Hi hopefully someone can help me with a couple of problems with AutoCAD layers.
First in the tree it groups the xref files by Layer. I would like it to group them by xref and then the various layers inside that model under it. this is what I get
the second issue is that the layers in the properties are the same. If I try and use the appearance profiler to turn all beams to a different colour I cant use layer as they are all different i cant just use the layer of S_Beams.
Any help would be much appreciated
Cheers
Dave
PatrickDavis20
You might want to reach out to [email protected] at iConstruct. If you are not familar with iConstruct, it is an addon to Navisworks that adds a lot of functionality. I believe that iConstruct can solve your problem.
Patrick Davis
Twitter
LinkedIn
Blog
a_meteni
You might try to un-check the Convert XRefs in the file Readers DWG Options and then Append XRef files separetly.
david.forsyth8QZCL
Thanks guys,
I know it's two different packages but when I bring in a .dgn file with references, it displays how I would like to see it
@a_meteniI run a batch script to auto run the navis so doing them manually is not really an option as we can have 1000's of files
If I untick the Merge Xref Layers I get close but the selection tree becomes quite messy
