Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Navisworks AutoCAD Layers
david.forsyth8QZCL
david.forsyth8QZCL
Hi hopefully someone can help me with a couple of problems with AutoCAD layers.
First in the tree it groups the xref files by Layer. I would like it to group them by xref and then the various layers inside that model under it. this is what I get
the second issue is that the layers in the properties are the same. If I try and use the appearance profiler to turn all beams to a different colour I cant use layer as they are all different i cant just use the layer of S_Beams.
Any help would be much appreciated
Cheers
Dave
PatrickDavis20
You might want to reach out to Rob.gadbaw@iconstruct.com at iConstruct. If you are not familar with iConstruct, it is an addon to Navisworks that adds a lot of functionality. I believe that iConstruct can solve your problem.
Patrick Davis
Twitter
LinkedIn
Blog
a_meteni
You might try to un-check the Convert XRefs in the file Readers DWG Options and then Append XRef files separetly.
david.forsyth8QZCL
Thanks guys,
I know it's two different packages but when I bring in a .dgn file with references, it displays how I would like to see it
@a_meteniI run a batch script to auto run the navis so doing them manually is not really an option as we can have 1000's of files
If I untick the Merge Xref Layers I get close but the selection tree becomes quite messy
