Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
When I use the measure tool, the dialog box that shows the measurements frequently obscures the convergence point for the xyz lines. Obviously I can rotate the view to see them, but many times that wouldn't necessary if I could just see them right off. Is there any way to get this box to move out of the way, or to set it at a default location that is away from the xyz lines?
Solved by a_meteni. Go to Solution.
Short answer is No. not without orbiting the model to a good view like you said. However, there’s a way to get the three measurements “one at a time” by hitting X, Y or Z after picking your first point on screen and Navisworks will lock the measurement to that axis only.
Thanks for the feedback! I’d rather ask from the dev team to focus on more "major" future updates rather than the measurement issue 🙂
