Navisworks 2016 (Freedom and Simulate) Display Issue
TrevorFreeman7268
Message 1 of 19
TrevorFreeman7268
We are experiencing a weird display issue with NAvisworks.
When we dock or undock the Poperties window the graphics go temporarily pixelated in th emain display.
They reset once you move the pointer around and the screen regens.
We have updated our Firepro W4100 drivers to the latest and stil have the same issues.
Replies (18)
Message 2 of 19
dbobetsky
I am having similar issues with Navisworks Manage, but it is basically unusable. I have uninstalled and reinstalled the software. the viewcube and the nav bar are unrecognizable, and the nav bar doesn't work at all.The view cube is basically exploded. If i try to use it, the drawing turns into millions of unrecognizable pixels. Without moving the display, you can notice that I have multi-colored trusses, ductwork and equipment. Does anyone have any suggestions? I don't have these issues with Navis Manage 2015....This is frustrating!!
Message 3 of 19
Lance.Coffey
Autodesk Support
Autodesk Support
I am not seeing this behavior on my system, when working with the sample files (e.g. enviro-dome.nwd). Do you also see this issue when working in the sample files (i.e. is it specific to the files you were working in)?
Lance Coffey
Technical Support Specialist
Message 4 of 19
TrevorFreeman7268
The .nwd sample files seem to be OK. However the cad files and .nwf files are still showing the garbled display when turning the properties window on and off.
Message 5 of 19
dbobetsky
The view cube is all exploded looking even when I just open Navisworks without a drawing. It doesn't matter what file I open. All files are fine in 2015 navisworks manage. They are also fine in 2016 Navisworks Simulate.....It doesn't make sense. I have reinstalled already, but may have to do a clean uninstall. Not sure....
Message 6 of 19
Lance.Coffey
Autodesk Support
Autodesk Support
@dbobetsky, here’s an article with information on the clean uninstall process:
How to cleanly uninstall Navisworks 2016
Lance Coffey
Message 7 of 19
dbobetsky
thank you. I'll give this a try.
Message 8 of 19
Lance.Coffey
Autodesk Support
Autodesk Support
@TrevorFreeman
I tested the Gatehouse.dwg sample file on my system and I'm not seeing the issue described. Here is a video showing the steps I went through:
Can you reply with a video showing the display issue with this same file?
Lance Coffey
Message 9 of 19
dbobetsky
I'm afraid I don't know how to post a video. It is asking for a URL...do i need to post it to youtube or something first?
Message 10 of 19
Lance.Coffey
Autodesk Support
Autodesk Support
There are many ways to provide a video (YouTube is one).
If you want to embed a video like I did, you would go to the Screencast page, download the utility, record the video, upload as a video for "Everyone" and then you will have a URL to paste.
More information on using this Autodesk service is available in the following article:
How to use Autodesk Screencast to document a support issue
Lance Coffey
Message 11 of 19
dbobetsky
our IT guy is out this week, and I don't have permission to install the screencast app to upload the video. At anyrate, if you just look at my posted image you can see what my Navis looks like. All you need to look at really is the view cube and the navigation bar. that is what I see when I first open Navisworks without a file opened. they both look exploded. the nav bar doesn't work at all.When I click on the view cube to spin it..even very slowly, the view cube itself looks worse and any model I have open becomes millions of pixels...Maybe my first step, when our IT guy returns, is a clean uninstall and then a reinstall of Navisworks...I'll let you know if that works.For now I am staying on 2015
Message 12 of 19
Lance.Coffey
Autodesk Support
Autodesk Support
I agree that the screenshot is enough to convey the issue you are seeing with the view cube within Navisworks.
If a clean uninstall/reinstall doesn’t clear the issue, it would be good to check the MS .NET Framework
Lance Coffey
Message 13 of 19
dbobetsky
did a clean install and it still looks the same...pretty aggravated .....
Message 14 of 19
Patrick_Aps_9121
Check your display options: deselect all hardware acceleration and DirectX and OpenGL versions.
Close and restart Navisworks.
See if it works.If it does, select only the oldest DirectX version.
If that works, DEselect the oldest Direct X version and select the one above
Message 15 of 19
TrevorFreeman7268
Sorry for the slow reply been on summer holidays.
This worked thank you.
Message 16 of 19
dbobetsky
THANK YOU!! All I did was turn off Hardware Acceleration and it is all good.
Message 17 of 19
This solution also works for BIM 360 Glue.
Message 18 of 19
Thanks! this worked for me as well.
Message 19 of 19
