Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Model colors are stuck on grayscale
14 REPLIES 14
Message 1 of 15
3109 Views, 14 Replies
The 2D in Navisworks shows up with correct colors. The 3D models shows up as greyscale. Color stays a grayscale even after changing the color.
14 REPLIES 14
Message 2 of 15
J450NP13
What software are you modeling in?
Message 3 of 15
dgorsman
You've probably got the render mode and lighting both as "Full", along with no materials and default lighting.  Change the lighting to "Scene" or "Headlight" and rendering to "Shaded".
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 4 of 15
in reply to: J450NP13
Bentley Autoplant, Bentley Prosteel and AutoCAD
Message 5 of 15
in reply to: dgorsman
The rendering is set to shaded. Headlight is set to max. Scene Light is set to less then 50%.
Message 6 of 15
J450NP13
Are you exporting out of autoPlant or importing autoPlant into Navis?
If you are exporting.....check to see if there are check boxes for exporting material or something to that effect.
Message 7 of 15
I am appending all files in Navisworks. All boxes that say Bentley and AutoCAD are checked. I can change the materail of the objests, but it will not let me change the color from gray.
Message 8 of 15
J450NP13
Did you right click and go to override item>color?
Message 9 of 15
Yes. I tryed to override the color and transparency. Both are not working.
Message 10 of 15
J450NP13
Are you using Freedom or Manage?
Message 11 of 15
Naviswork Simulate 2015.
Message 12 of 15
J450NP13
Sorry,  I haven't used Simulate yet.  I am not sure what kind of features you have access to ....or if it is more for reviewing than altering.
Message 13 of 15
Navisworks 2015 rendering was set to Full Render. It needed to be set to Shaded. The option to change this is located in a different place as well. Follow these steps and it will fix the problem.
  1. Right click on an object
  2. Go to Viewpoint
  3. Go to Rendering
  4. Select Shaded
Message 14 of 15
I tried that but it didn't help.
Why do I lose all the colors when I append the files?
I have the same problem with the buildings etc.  They are all grey....
Message 15 of 15
Same problem in Navisworks 2019.
I change the colour and transparency and it is always grey.
Any help?
Rail Community
