How to cut horizontal sections
Hi All,
Brand new to NW, so sorry if this is a basic question. I have a multi floor building model. How do I cut a horizontal section so I can see various heights of the building.
EV
Patrick_Aps_9121
Only when you have Floors and Axes defined and exported from Revit, you have this functionality build in.
If not, you need to create Clip Boxes manually and save those as viewpoints
Hi @Anonymous,
if I were you I would do this in Revit, with the section box tools in 3D view or directly using sections.
If you want to use Navis you can use the section plane and use the alignment of a facade to create it!
Best
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Infraworks Ambassador
Want to present in Infraworks? Vote this up!
Thanks, I created clip boxes and saved them as viewpoints to see the levels I wanted. I appreciate the help
