Hi all,
thanks for any help in advance.
so I'm using Revit 2021 and Navisworks manage 2021.
when I export Revit to Navisworks i get very rough edges on round models.is there anyway to get a really high resolution for presentation purposes.
Do I need to amend the Revit file before exporting or is this a
Navisworks issue?
a lot of the problem families have imported cad files as their basis,would this be the issue ,is it esay to correct without redrawing the families?
see attached current NWD snapshot
Hi all,
Navisworks issue?
Solved by brett_parkerLUEP7. Go to Solution.
Hello
Thank you for posting to the forums.
There isn't a specific way in Navisworks to update resolution. However, file loaders have Faceting Factor/Max Facet Deviation settings that may affect this. It is worth checking with the authoring tool (Revit) if this can be updated before export/save.
Regards
Hello
Regards
thanks brett i will explore this route and let you know how i got on
it was for dwg imported families only.so i ended up just changing them out
