Clash Detection - Rules
jesseHLKB5
jesseHLKB5
I am looking to eliminate clashes that are caused by duct, pipe, and conduit penetrating through walls. I am aware of the "Items in Previously Found Pair of Composite Objects" that seems to be available in previous versions of Navisworks; however, it is not available in 2018. Is there a rule, or a manipulation of a rule that would allow for these clashes to be removed from the results?
craigjonnson
Hi, have you considered searchsets? This works for me, basically searching for walls that are concrete, in-situ material within the Architectural and Structural files. The clash results only report out the walls where penetrations are then required.
Indeed! Why would they get rid of that rule?
