Cannot Open revit file in Naviswork 2022
When i try to open a revit file in Navisworks 2022. It shows that the file cannot be open because of internal error. How to solve this problem.
a_meteni
Check this link from AKN.
hmunsell
  • open the Revit model and run a Purge all Unused (may need to be run several times to fully clean everything out).
  • when Syncing to Central make sure the Compact Central Model is checked
  • try loading the file into Navisworks again....
If that didn't work:
  • open the file Detached  and save it as a new name.
  • try opening the detached model.
Depending on the version of Revit your running, you can also load the Navisworks tools, found under Add-Ins ribbon >  External Tools. I believe newer versions of Revit has the included by default older versions of Revit you may need to find the install for it. Use that to make a NWC and open the NWC into Navisworks.
Howard Munsell
miano_s
Hi, I have the same problem with the revit 2021 and navisworks 2022 update 1 files. I can't upload the files with this error. I tried with your solution but it doesn't work. How to solve?
s. miano
MattDeMeo
Try Navisworks 2021.  Not a fix but a workaround that worked for me. I check the Options > File Readers for Revit and dwg and they seem to have the same settings from 2021 to 2022 also unchecked everything still did not work.  I tried it with NavisWorks 2022 and 2022.1 both give errors.
