cannot add SP1 to a Deployment
Patrick_Aps_9121
Advisor Advisor
Patrick_Aps_9121
I tried
Maodfy an existing deployment
Create a new deployment using an existing as template
And in a 3rd attempt even
but in all tree scenario's the "include a Service Pack" options remain greyed out and the message "this product is up to date" is standing there.
Any advice on how to proceed ?
Patrick_Aps_9121
It does not matter if I start the
"Tools\Create & modify a deployment.lnk" from the network location where the deployment is located
or if I start the Setup again from within the original downloaded Navisworks_Freedom_2014_dlm which is located on my local hard drive.
I have this issue both with my Freedom and my Simulate Deployment
I always get the message "This product is up-to-date. No Service Pack is available"
and cannot select "Include Service Pack(s) from loacl drive or local network"
DarrenP
same problem here also
DarrenP
DarrenP
its the same with the Building Design Ultimate 2014 Suite also
DarrenP
DarrenP
i would avoid putting the service pack on
DarrenP
Patrick_Aps_9121
Well I have not jet deployed Navisworks 2014 in my organisation, due to the "viewpoints import error". So to be sure that all installations would have the SP1, I very much would like to have a deployment that includes SP1, rather than running SP1 on each machine seperatly in a 2nd fase.
Patrick_Aps_9121
Autodesk has changed something on their webserver overnight. The Problem is solved now.
