05:26 AM
1) Batch Utility doesn't read .dri file as input while using batch utility to convert to .nwd
2) I had around 600+ files in a .txt file and had this input as list to the batch utility , It reads to a certain no (300+) and stops reading the files beyond that .
An error occurred: Failed to append file
Autodesk.Navisworks.Api.DocumentFileException: Failed to append file
at Autodesk.Navisworks.Api.Document.AppendFile(String fileName)
at Autodesk.Navisworks.FiletoolsTaskRunner.CNWTaskRunner.Run(CNWTaskInputFiles in_files, List`1 readable_file_exts)
Has anyone experienced this problem
