Message 1 of 14
- Mute
- Permalink
- Report
.nwd files are set to open with Freedom by default. The file name is "Roamer.exe"
I wanted to change it to Manage by default. The file name is also "Roamer.exe"
Windows 10 doesn't know the difference. Even when you follow the path to find a different app, Windows believes that since the filename is the same, there was no difference in path. So, it is still opening with Freedom.
How do I fix this?
I've also noticed that Manage has an additional instruction to the shortcut. See attached image.
Is this what windows needs in the default?
