Hi @Anonymous,
I was going through the Schedule Simulation on naviswork Timeliner and wonder how to see the original duration column on the timeliner window. I couldn't find the duration column on the timeliner.
By original duration column on the timeliner window do you planned start and End date which is available by default in Navisworks. If you are looking for something different you can choose from "Choose Timeliner Columns" Dialogue box you can add User specific parameters as well.
Another most important requirement missing in this section is Logic Link between the task . Since there is an option of adding the task manually in the timeliner, why don't we have the logic link facility ?
Please use auto-attach using Rules option in the timeliner.
Jebakumar
BIM Specialist
