WPF ViewControl Error
I'm brand new to NavisWorks development and I'm having an issue getting the ViewControl to work in a WPF application. I've tried to use the sample app in the SDK and also build my own from scratch. Both give the following error:-
The name "ViewControl" does not exist in the namespace "clr-namespace:Autodesk.Navisworks.Api.Controls;assembly=Autodesk.Navisworks.Controls".
I'm using Windows 10 64 bit with the anniversary update and the 2017 version of the SDK.
Does anyone have any ideas?
Geoff
xiaodong_liang
Autodesk Support
Autodesk Support
Hi Geoff,
I guess you hit a the related issue that is mentioned in the other post, i.e. Viewer control in release 2017 cannot work. The issue has been addressed and a fix would be probably available with SP1.
http://forums.autodesk.com/t5/navisworks-api/confusing-navisworks-api-not-licensed-error/td-p/643067...
In another word, it should not be a problem with WPF, but Viewer control itself.
hi please Try this:
use in xml code :
<WindowsFormsHost x:Name="mFormsHost" >
<!--<NwControls:ViewControl x:Uid="viewControl"
x:Name="viewControl"
Dock="Fill" />-->
</WindowsFormsHost>
and in c# code:
after
InitializeComponent();
var viewControl = new Autodesk.Navisworks.Api.Controls.ViewControl();
viewControl.Name = "viewControl";
viewControl.Dock= System.Windows.Forms.DockStyle.Fill;
mFormsHost.Child = viewControl;
viewControl.DocumentControl = " your Document for example oDoc"
