error in "Navisworks.Timeliner.Plugin"
Hello;
I am using nw api and i assign some values to timeliner tasks "user1" and "user2" using TaskReplaceWithCopy.
it works for first and second run and assigns my value to all timeliner taks ; but when pressing button for third time a highlighted green error displays in my code , on the line TaskReplaceWithCopy (means external error);
propoerties of the erorr are as follow:
- $exception {"Object reference not set to an instance of an object."} System.Exception {System.NullReferenceException}
- Source "Navisworks.Timeliner.Plugin" string
StackTrace " at Autodesk.Navisworks.Timeliner.VM.GanttVM.GetTaskIndex(GroupItem task)\r\n at Autodesk.Navisworks.Timeliner.VM.GanttVM.CanIndent(TimelinerTask task)\r\n at Autodesk.Navisworks.Timeliner.VM.GanttVM.IsIndentValidForCurrentSelection()\r\n at Autodesk.Navisworks.Timeliner.VM.TasksTabVM.<.ctor>b__22(GanttVM vm)\r\n at System.Windows.Controls.Primitives.ButtonBase.UpdateCanExecute()\r\n at Microsoft.Practices.Prism.Commands.WeakEventHandlerManager.CallWeakReferenceHandlers(Object sender, List`1 handlers)\r\n at Autodesk.Navisworks.Timeliner.VM.TasksTabVM.OnGanttSelectionChanged()\r\n at Autodesk.Navisworks.Timeliner.VM.TasksTabVM.get_Gantt()\r\n at Autodesk.Navisworks.Timeliner.VM.TabsWindowVM.OnTimelinerCurrentTaskChanged(Object sender, TimelinerCurrentTaskNotifyEventArgs e)\r\n at Autodesk.Navisworks.Api.Interop.TimelinerCurrentTaskNotify.OnCurrentTaskChanged(Boolean from_external)\r\n at Autodesk.Navisworks.stub.LcTlCurrentTaskNotify.OnCurrentTaskChanged(LcTlCurrentTaskNotify* , Boolean is_from_interop)" string
any idea about this?
