I have built a Navisworks Manage 2022 Ribbon dll and I want to check the ribbon in navisworks. So where can I use my dll file in Navisworks. If you can please share the location and dependency file path it would be great help. @Anonymous
Solved by naveen.kumar.t. Go to Solution.
Hi @Anubhav_SinghRJX69 ,
How did you create a ribbon?
Is it via XAML?
I would suggest you take a look at this below link.
The below link shows you where to place the files for creating a ribbon in Navisworks.
https://twentytwo.space/2022/02/02/navisworks-api-commandhandlerplugin/
I would also suggest you see the "Additional Reference" section present in the above link.
Hi Naveen, Thanks for your reply.
Is there any other location where we can keep the dlls as we don’t have access to the following location (“C:\Program Files\Autodesk\Navisworks Manage 2022\Plugins”) as shown in the link that was provided in this email.
As far as I know, you can create a bundle and place the bundle in any one of the below mentioned locations
The per-user root folder is: %APPDATA%\Autodesk\ApplicationPlugins
The per-machine root folder is: %PROGRAMDATA%\Autodesk\ApplicationPlugins
For more information, Please take a look at this below link
https://www.autodesk.com/developer-network/app-store/navisworks
