Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
Automatic Appearance Profiler before NWD Creation
2 REPLIES 2
ChristianMolino
282 Views, 2 Replies
I am trying to find an easy workflow to automate nwd creation and found some info on how to do that, however I need to run an appearance profiler before creating the nwd. Ideally I would like to just have the whole process run overnight and have a fresh, color coded nwd every morning.
Does anyone know of anything existing that can do this or has successfully set something up like this through the API?
I took some coding classes in highschool and college, but am not a developer by any means so diving into the API will be new for me.
2 REPLIES 2
You can do with combination of command line args.Use AutoAppearanceLoader.
https://forums.autodesk.com/t5/navisworks-forum/appearance-profiler-automatic/td-p/3220852
Could you please take a look at this below link?
https://adndevblog.typepad.com/aec/2022/05/setting-appearance-profiler-dat-file-via-navisworks-api.h...
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Rail Community
