Appearance Profiler: Automatic
dennis
Advisor Advisor
Message 1 of 15
dennis
Is there a way to get the Appearance Profiler to "run" automatically when the NWF file is opened?  Or am I looking at an API program?
Replies (14)
Message 2 of 15
dembkod
Dennis,
Hello. There is currently no way to force an appearance profile to automatically load. You can save a profile and transmit the saved file along with your model, but it will not force a load of the profile when a model is opened.
I am unsure if this can be accomplished with the API, but it may be. I would as you log this as an enhancement request with our developers directly. You can do so here:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Thank you for participating in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
David Dembkoski
Message 3 of 15
dennis
Good idea, and is done.
Message 4 of 15
Are there any updates on this? maybe there is Add-in that does this? Really need this feature!
Message 5 of 15
any update on this topic? Navis really needs this feature
Message 6 of 15
Gangula2
Is it currently available in Navisworks 2016?
Message 7 of 15
No it is not. Nor 2017 for that matter...
Message 8 of 15
I have recently installed Manage 2019 hoping that this issue of the Appearance Profiler not getting written to the file just like Sets or Saved Views. I am pretty devastated to see that nothing has been done seeing this was first requested back in 2011.
Do the developers not listen to the users requests?
Message 9 of 15
pbusciglio
Apparently they don't listent to requests.  There are so many small features that would make Navisworks so much better, but they don't want to implement.  In the meantime, there are growing alternate solutions to perform the functions Navisworks does and then some.
Message 10 of 15
hbds20
this needs to be implemented.
Message 11 of 15
s.hamel
Navisworks 2023 now includes this ability:
-ExecuteAddInPlugin AutoAppearanceLoader.Navisworks <appearance.dat>
The following will produce the nwd with the appearance profiler settings in 'appearance.dat' applied to the scene
Roamer.exe -OpenFile <input.nwf> -ExecuteAddInPlugin AutoAppearanceLoader.Navisworks <appearance.dat> -SaveFile <out.nwd> -Exit
Shayne Hamel
Manager, Principal Software Engineering
Message 12 of 15
pbusciglio
Is there documentation on this?
Message 13 of 15
s.hamel
Currently just the entry on the enhancements page: https://help.autodesk.com/view/NAV/2023/ENU/?guid=Navisworks_2023_enhancements
Other pages will be updated in due course.
Shayne Hamel
Message 14 of 15
pascal.robben
ok, good to know but.... is it an actual plugin? where to dowwnload and install? not very clear for me.
What steps to take within navisworks and can I use several appearance profiles for the different projects?
Or is this plugin always refering to the same DAT file?
-ExecuteAddInPlugin AutoAppearanceLoader.Navisworks - [appearance.dat] - Execute the specified add-in and automatically load and apply appearance profiles
Message 15 of 15
s.hamel
It is shipped with Navisworks, nothing additional to install. Nothing to do when you are in Navisworks, this is simply for when launching from the command line. You can integrate it as part of you file batching process if you use that, or create your own bat files or any other method that calls roamer.exe
You would replace [appearance.dat] with the path and name of the dat file you want to have applied, so yes you can use different ones for different projects.
Shayne Hamel
