Navisworks API: Point Line Measurement, extract intermediate coordinates\points
shaungsaggers
shaungsaggers
Does anyone know if it's possible, using the Navisworks API, to get the intermediate coordinates for the points used to take a Point Line Measurement?
I have created a plugin that returns the Start and End coordinates of the current measurement, and can export these to a text file, however I want to get ALL of the points along the measured Point Line.
My alternative would be to learn how to create a new tool via the API and capture the points as they are picked, but that sounds like a lot more work just to learn how to create the tool, and I can't justify that much overhead for this task, so I'd prefer to find a way to extract the points picked using the built in Point Line Measurement tool.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @shaungsaggers ,
You're question doesn't really make sense. There are an infinite number of points along a line...
Or are you wanting to get all the points in a multi-point measurement? If so, I think you can listen to the event and just capture them that way (i.e. the end point will keep changing)
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
shaungsaggers
It probably makes more sense if you're familiar with the measurement tools in Navisworks. In the software (as well as the classes available to the API), a "Point Line" measurement measures the cumulative length along a path defined by a series of specified points.
It's those intermediate points that I was hoping to be able to get AFTER the measurement has been made.
I've since solved it, by getting the points as they are picked. Not quite the way I was hoping it would work, but it'll do the
job.
