Excel cell hyperlink to Navisworks viewpoint
Shmuel-rozenberg
Observer Observer
Shmuel-rozenberg
Observer
Observer
Is there an easy way of clicking a cell in excel, specifying the viewpoint name, and then Navisworks pops up displaying the said viewpoint?
any help much appreciated.
S.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Shmuel-rozenberg ,
I am not sure how to trigger button clicks in Excel via C# code.
I would suggest you figure that out on your own.
But once the button is clicked, you can open and view the viewpoint via the Navisworks automation API.
Automation API - https://apidocs.co/apps/navisworks/2017/87317537-2911-4c08-b492-6496c82b3ed7.htm
You can access the saved viewpoints, get the required viewpoint by specifying the viewpoint name and make the required viewpoint as current viewpoint.
I hope this helps.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
jeroen.platteeuw
Community Visitor
Community Visitor
Dear Rozenberg,
I am very interested in wether you have solved this question. I am looking to do the same thing. Export viewpoints from naviswork to excel and keep it dynamic by linking the excel with a naviswork model. So if ther is an update I can click on a name in the excel file and the viewpoint shows in Naviswork to see the update.
tetsuya_miwa
The simple way to achive this is to create plugin to get instance of Excel application and hook active worksheet's selection change event.
Developing custom protocol handler to work with hyperlink is quite difficultto achieve with current Navisworks API.
https://forums.autodesk.com/t5/navisworks-api-forum/adding-protocol-handlers-to-navisworks/m-p/72532...
