How to include codes in post build event setup.exe. Creating plugins setup.exe c# winform navisworks api
aykcan46
aykcan46
I want to publish the naviswork plugin I wrote in the autodesk store and I want to create a setup to share with other users. However, I cannot include the things I wrote in the post build event, such as image language, in my setup folder. Can you help me.
Regards
aykcan46
@naveen.kumar.t  help me pls
naveen.kumar.t
Autodesk Support
Autodesk Support
HI @aykcan46 ,
I don't understand what you mean by you could not include the things you wrote in the post-build event.
I don't have much experience with post-build events, so if you explain your issue in detail, it will be helpful for me to understand your issue. (If possible, explain the issue with the screenshots)
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
aykcan46
I want to prepare the plugin I made in Visual Studio as an installation file. The image file in the Plugins folder we specified in the post build does not detect my codes for the dlls of the plugins I wrote for Dependencies. I want the installer to install and use it quickly without hassle. @naveen.kumar.t
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @aykcan46 ,
Sorry, I have no clue.
Basically, you want to publish your app in the Autodesk App Store. For that, you want to create an installer.
Here the image you are referring to is the plugin image, which will be shown when the app is installed on the pc.
Is my understanding correct?
If yes, then I think it is better to contact the Autodesk App Store team. The Autodesk App store team will help you to create an installer.
To Contact the Autodesk AppStore team, please take a look at the below link
https://www.autodesk.com/developer-network/app-store
You can contact them directly via appsubmissions@autodesk.com
Naveen Kumar T
aykcan46
Hi, @naveen.kumar.t
Thank you, Yes, you got it right. I will do what you say
Regards
