Does anyone know why my function for exploding empty groups is not working properly?
mtrainottiGHXJH
mtrainottiGHXJH
Below is my function for exploding empty groups and removing an item from a group if it is the only item in a group. This function works as expected with the caveat that I have to run it multiple times to remove all the groups. I have tried several solutions including rerunning the test recursively every time a group is removed until it does not return but this still does not work. I think it may have to do with do with items moving around the testdata in the same step(idk). Does anybody have any ideas for a solution or a method to await the testdata refreshing after an item is moved?
        void explode_empty_groups()
            var tests_data = doc_cd.TestsData.Tests;
            foreach (ClashTest ctest in tests_data)
                    foreach (SavedItem _item in ctest.Children)
                        if(_item.IsGroup)
                            ClashResultGroup clash_group = _item as ClashResultGroup;
                            if (clash_group == null)
                                //isgroup & null
                                doc_cd.TestsData.TestsRemove(ctest, _item);
                                continue;
                            //move child out
                            if (clash_group.Children.Count == 1)
                                doc_cd.TestsData.TestsMove(clash_group, 0, ctest, 0);
                                doc_cd.TestsData.TestsRemove(ctest, clash_group);
                                continue;
                            //remove group
                            if (clash_group.Children.Count == 0)
                                continue;
                return;
mtrainottiGHXJH
Also the return after a single clash test intentional as I am testing this over 1 clash test currently.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @mtrainottiGHXJH ,
I am able to reproduce the issue.
I have raised your issue to the Navisworks Engineering team.
But I haven't received any response from the engineering team yet.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
naveen.kumar.t
Autodesk Support
Autodesk Support
I still have not received any response from the NW Engineering team.
So I have logged the issue( NW-58887 ) with the Navisworks Engineering team.
Naveen Kumar T
naveen.kumar.t
Autodesk Support
Autodesk Support
I had a discussion with my team.
The below sample code will help you.
 private void Code(Document doc)
            DocumentClash docClash = doc.GetClash();
            DocumentClashTests tests = docClash.TestsData;
            foreach (ClashTest test in tests.Tests)
                var groupToDelete = new List<ClashResultGroup>();
                foreach (SavedItem savedItem in test.Children)
                    if (savedItem is ClashResultGroup)
                        ClashResultGroup resultGroup = savedItem as ClashResultGroup;
                        string resultGroupName = resultGroup.DisplayName;
                        //If the group does not have any clash, the group will be deleted
                        if (resultGroup.Children.Count() == 0)
                            groupToDelete.Add(resultGroup);
                foreach (ClashResultGroup resultGroup in groupToDelete)
                    docClash.TestsData.TestsRemove(resultGroup.Parent, resultGroup);
Naveen Kumar T
mtrainottiGHXJH
I appreciate your help! I wasn’t aware you could remove this way.
