How to convert Quantification workbook from Excel to XML?
I wanted to create a Quantification workbook as per the RICS NRM 1. I have prepared the same in Excel and want to load the same into Navisworks. How do I convert the Excel file to XML so I can load it into Navisworks?
xiaodong_liang
Autodesk Support
Autodesk Support
hi,
I have not a quick answer in my mind.
if RICS NRM 1 is a template of a catalog, I think you would need to check the format of an XML template, and follow such format to convert Excel template yourself. though I can be wrong.
