Export Image using Use Aspect Ratio
Hi
I am using of Navisworks  API plugins to export image.
following is code
opt.value = "lcodpexjpg"
opt.value = 500 'Width
opt.value = 500 'Height
Size as
Type =Use Aspect Ratio
Hieght  and width based on screen.
Export Image using "Use Aspect Ratio" optioin.
Navis works allow user to export image manually with following options
Format : JPG,PNG
Render: ViewwPort
Type: Explicit, Use Aspect Ratio, use view
Width: user defined
Height: user defined
In this case, we need to supply Export format, Width and Height.
Example
format = "lcodpexjpg"
width = 500
height= 500
Now I want to epxort Image using "Use Aspect Ratio" option.
Export format is JPG
Hieght and width based on Navisworks screen.
How to get type using Navisworks API plugins
Some explain how to export Image using "Use Aspect Ratio"thourgh Navisworks Api
