Is there a way to split a pipe in two different pipes?
alexandrescoelho
alexandrescoelho
Hi
As the question suggests, I want to split a pipe (eg: a pipe with 5000mm) in two pipes with 2500mm. Is that possible to do with navisworks API?
Any suggestions is welcome,
Thanks in advanced.
xiaodong_liang
Autodesk Support
Autodesk Support
Navisworks is a kind of product that manages the model. It has not the ability to 'design'. So it cannot edit the model elements such as adding new objects, deleting them or spliting. neither does API.
about adding new objects, an approximate way is to append a new model (say a model with the specific element only), but it cannot be merged to the model structure of the base model.
about deleting, you can only make the visibility of the object by Hidden methods.
as to spliting, you have to turn to the design software of the  orignal CAD file.
Dear alex,
If you want in Revit to split a single pipe into two pipes. this is possible.
Thanks.
