Dynamically Loaded Plugin Custom Tab Not Loading
logikgate
logikgate
I have one plugin that dynamically loads another via the below code.  Both of these plugins have their own custom ribbon tabs.  If I call the below code during the initialization of the first plugin both tabs show up fine.  If I call the below code from a button in the first plugin's ribbon tab the second plugin's tab never shows up even though the second plugin is indeed loaded which I have verified via debugging and the AppInfo window of Navisworks.
Is there something that I have to do in order for Navisworks to "realize" that the dynamically loaded plugin has it's own custom tab?
            PluginRecord record = Application.Plugins.FindPlugin(pluginNameString);
            if (record != null)
                if (!record.IsLoaded)
                    record.LoadPlugin();
Rene_Gerlach
Hi logikgate,
i had also some issues with my RibbonLayout.xml.
So may be some icons/text are not found on demand loading (diffent paths?)
Bad thing is, that the log nothing say about whats missing -> Could be enhanced at Autodesk side.
Good luck
Cheers
René
logikgate
Thanks @Rene_Gerlach  I tried removing all icon images and have verified (via logs) that when the plugin is loaded dynamically Navisworks is indeed finding the *.name and *.xaml files.
At this point I'm wondering if Navisworks just doesn't update the Ribbon when a plugin is loaded dynamically.  Has anyone successfully dynamically loaded a plugin that has a custom ribbon tab?
Plugin FlyPaper.Sherlock.AddIns.FlyP StringsAttribute(Sherlock.name) : Attempting to load strings...
LcUResource::FindLocalisedFile found C:\Users\abc\AppData\Roaming\Autodesk Navisworks Manage 2015\Plugins\FlyPaper.Sherlock\en-US\Sherlock.name
StringsAttribute : Loading SUCCEEDED from C:\Users\abc\AppData\Roaming\Autodesk Navisworks Manage 2015\Plugins\FlyPaper.Sherlock\en-US\Sherlock.name
LcUResource::FindLocalisedFile found C:\Users\abc\AppData\Roaming\Autodesk Navisworks Manage 2015\Plugins\FlyPaper.Sherlock\en-US\Sherlock.xaml
Rene_Gerlach
Hello logikgate,
maybe this help: Use Same Tab with Different Plugins
https://forums.autodesk.com/t5/navisworks-api/use-same-tab-with-different-plugins/td-p/5760643
And on loading activate the Ribbon like in sample CustomRibbonHandler.cs - CanExecuteRibbonTab
one workaround could add all needed ribbon/ribbonpanel etc dynamically without the xml.
You can use again the AdWindow.dll (like mentioned in Localize RibbonPanel Title in Name File ) and Autodesk.Navisworks.Gui.Roamer.AIRLook functions to do so.
Cheers
René
i believe this might be a better way. I have had no issues using this approach. with some tweaking yous should get this to work the way that you need it too
http://adndevblog.typepad.com/aec/2016/01/add-custom-panel-and-button-to-built-in-tab-of-navisworks-...
