Custom Ribbon Error...
Hello...
In Navisworks Manage 2017 & 2018, it was built and used without any problems.
Build does not work in Navisworks Simulate 2019.
"Adwindow.dll", "Autodesk.Navisworks.Api.dll", "navisworks.gui.roamer.dll" 3 files were referenced.
When building a solution, an error occurs and the build does not work.
The error message is as follows.
The XML Namespace'clr-namespace:Autodesk.Navisworks.Gui.Roamer.AIRLook;assembly=navisworks.gui.roamer' does not have the'NWRibbonButton' tag.
Please refer to the figure below for the created xaml code.
ulski1
Please install the Navisworks 2019 SDK and test if you can build the ribbon sample project
Br
Ulrik
Ta7a
hello,
for my case I use Navisworks 2021 and I have issue in creating custom tab so i tried the project in the SDK but still face the same issue the tab won't be created
