FileResolving Event in VB.net
budinsky
budinsky
ProjectWise working path changes per user and I need to be able to change the filepath for each user.
Please provide a working example in VB.NET
ulski1
Most people program Navisworks plugins in c# hence most of what you will find is in c#. You should be able to convert it to vb.net yourself.
To play around with file resolve event you should look at the following links:
https://forums.autodesk.com/t5/navisworks-api/fileinteractiveresolving-event-and-getting-name-of-unr...
https://apidocs.co/apps/navisworks/2018/E_Autodesk_Navisworks_Api_Application_FileInteractiveResolvi...
br
Ulrik
